Time Before: 0.01989 seconds
Time After: 0.02692 seconds
Time Taken: 0.00703 seconds
Time Before: 0.02700 seconds
Time After: 0.02756 seconds
Time Taken: 0.00056 seconds
Time Before: 0.02780 seconds
Time After: 0.02802 seconds
Time Before: 0.02870 seconds
Time After: 0.03128 seconds
Time Taken: 0.00259 seconds
Time Before: 0.02808 seconds
Time After: 0.03688 seconds
Time Taken: 0.00879 seconds
Time Before: 0.04536 seconds
Time After: 0.04578 seconds
Time Before: 0.04827 seconds
Time After: 0.04956 seconds
Time Before: 0.04246 seconds
Time After: 0.04978 seconds
Time Taken: 0.00732 seconds
Time Before: 0.09199 seconds
Time After: 0.09216 seconds
Time Before: 0.11396 seconds
Time After: 0.11556 seconds
Time Taken: 0.00160 seconds
End call of global.php: 0.11794185638428
Time Before: 0.12659 seconds
Time After: 0.12675 seconds
Time Before: 0.12958 seconds
Time After: 0.13109 seconds
Time Taken: 0.00151 seconds
SET lastactivity = 1776877929, location = '/forums/private.php?do=newpm&explain=1&u=133064'
Time Before: 0.15194 seconds
Time After: 0.15224 seconds
Page generated in 0.15073490142822 seconds with 9 queries, spending 0.008821964263916 doing MySQL queries and 0.14191293716431 doing PHP things.
