Time Before: 0.01976 seconds
Time After: 0.02843 seconds
Time Taken: 0.00868 seconds
Time Before: 0.02854 seconds
Time After: 0.02900 seconds
Time Before: 0.02937 seconds
Time After: 0.02954 seconds
Time Before: 0.03041 seconds
Time After: 0.03303 seconds
Time Taken: 0.00262 seconds
Time Before: 0.02962 seconds
Time After: 0.03675 seconds
Time Taken: 0.00713 seconds
Time Before: 0.04691 seconds
Time After: 0.04749 seconds
Time Taken: 0.00058 seconds
Time Before: 0.05001 seconds
Time After: 0.05168 seconds
Time Taken: 0.00167 seconds
Time Before: 0.04616 seconds
Time After: 0.05188 seconds
Time Taken: 0.00572 seconds
Time Before: 0.08450 seconds
Time After: 0.08468 seconds
Time Before: 0.10576 seconds
Time After: 0.10718 seconds
End call of global.php: 0.10979223251343
Time Before: 0.11526 seconds
Time After: 0.11544 seconds
Time Before: 0.11809 seconds
Time After: 0.11955 seconds
SET lastactivity = 1783167342, location = '/forums/private.php?do=newpm&explain=1&u=133153'
Time Before: 0.13664 seconds
Time After: 0.13710 seconds
Memory Before: 4,912.039 KB
Memory After: 4,912.266 KB
Page generated in 0.13559722900391 seconds with 9 queries, spending 0.009190559387207 doing MySQL queries and 0.1264066696167 doing PHP things.
