Time Before: 0.02717 seconds
Time After: 0.03754 seconds
Time Taken: 0.01037 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03766 seconds
Time After: 0.03811 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03839 seconds
Time After: 0.03853 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03954 seconds
Time After: 0.04223 seconds
Time Taken: 0.00269 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03861 seconds
Time After: 0.04621 seconds
Time Taken: 0.00760 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.06031 seconds
Time After: 0.06077 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.06377 seconds
Time After: 0.06504 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.05960 seconds
Time After: 0.06531 seconds
Time Taken: 0.00572 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.10721 seconds
Time After: 0.10736 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.16695 seconds
Time After: 0.16818 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
End call of global.php: 0.17005300521851
Time Before: 0.19509 seconds
Time After: 0.19526 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.20030 seconds
Time After: 0.20178 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
SET location = '/forums/private.php?do=newpm&explain=1&u=133229'
Time Before: 0.22797 seconds
Time After: 0.22837 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
Page generated in 0.22683501243591 seconds with 9 queries, spending 0.0084493160247803 doing MySQL queries and 0.21838569641113 doing PHP things.
