Time Before: 0.01670 seconds
Time After: 0.02334 seconds
Time Taken: 0.00665 seconds
Time Before: 0.02343 seconds
Time After: 0.02403 seconds
Time Taken: 0.00060 seconds
Time Before: 0.02427 seconds
Time After: 0.02443 seconds
Time Before: 0.02525 seconds
Time After: 0.02750 seconds
Time Taken: 0.00225 seconds
Time Before: 0.02451 seconds
Time After: 0.03215 seconds
Time Taken: 0.00764 seconds
Time Before: 0.04023 seconds
Time After: 0.04047 seconds
Time Before: 0.04273 seconds
Time After: 0.04400 seconds
Time Before: 0.03953 seconds
Time After: 0.04424 seconds
Time Taken: 0.00471 seconds
Time Before: 0.07544 seconds
Time After: 0.07560 seconds
Time Before: 0.52868 seconds
Time After: 0.53017 seconds
Time Before: 0.54313 seconds
Time After: 0.54330 seconds
Time Before: 0.54603 seconds
Time After: 0.54747 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133236', badlocation = 1 WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.56642 seconds
Time After: 0.56672 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
