Time Before: 0.02573 seconds
Time After: 0.03777 seconds
Time Taken: 0.01204 seconds
Time Before: 0.03788 seconds
Time After: 0.03833 seconds
Time Before: 0.03861 seconds
Time After: 0.03874 seconds
Time Before: 0.03951 seconds
Time After: 0.04243 seconds
Time Taken: 0.00292 seconds
Time Before: 0.03880 seconds
Time After: 0.04624 seconds
Time Taken: 0.00744 seconds
Time Before: 0.05952 seconds
Time After: 0.05993 seconds
Time Before: 0.06327 seconds
Time After: 0.06481 seconds
Time Taken: 0.00154 seconds
Time Before: 0.05879 seconds
Time After: 0.06506 seconds
Time Taken: 0.00627 seconds
Time Before: 0.10896 seconds
Time After: 0.10911 seconds
Time Before: 0.13274 seconds
Time After: 0.13404 seconds
End call of global.php: 0.13636898994446
Time Before: 0.14162 seconds
Time After: 0.14175 seconds
Time Before: 0.14403 seconds
Time After: 0.14558 seconds
SET lastactivity = 1785408347, location = '/forums/private.php?do=newpm&explain=1&u=133256'
Time Before: 0.16375 seconds
Time After: 0.16406 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.16271901130676 seconds with 9 queries, spending 0.0088942050933838 doing MySQL queries and 0.15382480621338 doing PHP things.
