Time Before: 0.01484 seconds
Time After: 0.01863 seconds
Time Taken: 0.00379 seconds
Time Before: 0.01870 seconds
Time After: 0.01907 seconds
Time Before: 0.01927 seconds
Time After: 0.01941 seconds
Time Before: 0.02015 seconds
Time After: 0.02265 seconds
Time Taken: 0.00250 seconds
Time Before: 0.01947 seconds
Time After: 0.02690 seconds
Time Taken: 0.00743 seconds
Time Before: 0.03219 seconds
Time After: 0.03258 seconds
Time Before: 0.03494 seconds
Time After: 0.03615 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.03150 seconds
Time After: 0.03633 seconds
Time Taken: 0.00483 seconds
Memory After: 2,261.820 KB
Time Before: 0.05755 seconds
Time After: 0.05770 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
REPLACE INTO datastore
(title, data, unserialize)
VALUES
('loadcache', 'a:2:{s:7:\"loadavg\";s:6:\"36.70,\";s:9:\"lastcheck\";i:1788958519;}', 1)Time Before: 0.06980 seconds
Time After: 0.07047 seconds
Time Taken: 0.00066 seconds
Memory Before: 2,816.633 KB
Memory After: 2,816.883 KB
Memory Used: 0.250 KB
Time Before: 0.14881 seconds
Time After: 0.15085 seconds
Time Taken: 0.00204 seconds
Memory Before: 2,903.938 KB
Memory After: 2,904.531 KB
Time Before: 0.15905 seconds
Time After: 0.15922 seconds
Memory Before: 3,540.688 KB
Memory After: 3,541.117 KB
Time Before: 0.16176 seconds
Time After: 0.16329 seconds
Time Taken: 0.00153 seconds
Memory Before: 3,822.422 KB
Memory After: 3,824.109 KB
UPDATE session SET lastactivity = 1788958519, location = '/forums/private.php?do=newpm&explain=1&u=133259' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.18060 seconds
Time After: 0.18085 seconds
Memory Before: 4,296.156 KB
Memory After: 4,296.383 KB
