Time Before: 0.00150 seconds
Time After: 0.00202 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00209 seconds
Time After: 0.00259 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00283 seconds
Time After: 0.00295 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00386 seconds
Time After: 0.00646 seconds
Time Taken: 0.00261 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00304 seconds
Time After: 0.00984 seconds
Time Taken: 0.00681 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01170 seconds
Time After: 0.01207 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01437 seconds
Time After: 0.01556 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01113 seconds
Time After: 0.01573 seconds
Time Taken: 0.00460 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02067 seconds
Time After: 0.02080 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02267 seconds
Time After: 0.02387 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
End call of global.php: 0.025565147399902
Time Before: 0.02684 seconds
Time After: 0.02698 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.02904 seconds
Time After: 0.03043 seconds
Time Taken: 0.00139 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
SET lastactivity = 1776704187, location = '/forums/private.php?do=newpm&explain=1&u=133330'
Time Before: 0.04270 seconds
Time After: 0.04297 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
Page generated in 0.041837930679321 seconds with 9 queries, spending 0.0079116821289062 doing MySQL queries and 0.033926248550415 doing PHP things.
