Time Before: 0.01334 seconds
Time After: 0.01756 seconds
Time Taken: 0.00423 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.01767 seconds
Time After: 0.01814 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.01835 seconds
Time After: 0.01851 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.01930 seconds
Time After: 0.02185 seconds
Time Taken: 0.00254 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.01860 seconds
Time After: 0.02584 seconds
Time Taken: 0.00724 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.03057 seconds
Time After: 0.03098 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.03346 seconds
Time After: 0.03470 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.02994 seconds
Time After: 0.03489 seconds
Time Taken: 0.00495 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.05203 seconds
Time After: 0.05218 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.07968 seconds
Time After: 0.08096 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.10187 seconds
Time After: 0.10205 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.10686 seconds
Time After: 0.10834 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133401' WHERE sessionhash = 'a1024cf3a534e5ec94f7248e61d8a1ae'
Time Before: 0.12667 seconds
Time After: 0.12694 seconds
Memory Before: 5,997.547 KB
Memory After: 5,997.789 KB
