Time Before: 0.00825 seconds
Time After: 0.01093 seconds
Time Taken: 0.00268 seconds
Time Before: 0.01101 seconds
Time After: 0.01157 seconds
Time Taken: 0.00056 seconds
Time Before: 0.01184 seconds
Time After: 0.01205 seconds
Time Before: 0.01289 seconds
Time After: 0.01534 seconds
Time Taken: 0.00245 seconds
Time Before: 0.01212 seconds
Time After: 0.01938 seconds
Time Taken: 0.00726 seconds
Time Before: 0.02395 seconds
Time After: 0.02436 seconds
Time Before: 0.02580 seconds
Time After: 0.02699 seconds
Time Before: 0.02317 seconds
Time After: 0.02723 seconds
Time Taken: 0.00406 seconds
Time Before: 0.04743 seconds
Time After: 0.04758 seconds
Time Before: 0.05591 seconds
Time After: 0.05727 seconds
Time Taken: 0.00136 seconds
End call of global.php: 0.059931993484497
Time Before: 0.06443 seconds
Time After: 0.06461 seconds
Time Before: 0.06737 seconds
Time After: 0.06885 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=133434', badlocation = 1
Time Before: 0.08993 seconds
Time After: 0.09034 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.088837146759033 seconds with 9 queries, spending 0.0084152221679688 doing MySQL queries and 0.080421924591064 doing PHP things.
