Time Before: 0.02476 seconds
Time After: 0.03316 seconds
Time Taken: 0.00840 seconds
Time Before: 0.03324 seconds
Time After: 0.03377 seconds
Time Taken: 0.00053 seconds
Time Before: 0.03403 seconds
Time After: 0.03419 seconds
Time Before: 0.03489 seconds
Time After: 0.03775 seconds
Time Taken: 0.00286 seconds
Time Before: 0.03427 seconds
Time After: 0.04200 seconds
Time Taken: 0.00773 seconds
Time Before: 0.05095 seconds
Time After: 0.05130 seconds
Time Before: 0.05386 seconds
Time After: 0.05512 seconds
Time Before: 0.05020 seconds
Time After: 0.05531 seconds
Time Taken: 0.00511 seconds
Time Before: 0.09861 seconds
Time After: 0.09879 seconds
Time Before: 0.11642 seconds
Time After: 0.11768 seconds
Time Before: 0.13133 seconds
Time After: 0.13152 seconds
Time Before: 0.13397 seconds
Time After: 0.13544 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133454', badlocation = 1 WHERE sessionhash = 'dd14cf6af34df6bab38ac9fb3783395f'
Time Before: 0.15073 seconds
Time After: 0.15100 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
