Time Before: 0.00188 seconds
Time After: 0.00257 seconds
Time Taken: 0.00069 seconds
Memory Before: 1,159.359 KB
Memory After: 1,184.477 KB
Time Before: 0.00268 seconds
Time After: 0.00328 seconds
Time Taken: 0.00060 seconds
Memory Before: 1,184.414 KB
Memory After: 1,185.422 KB
Time Before: 0.00355 seconds
Time After: 0.00368 seconds
Memory Before: 1,186.008 KB
Memory After: 1,186.531 KB
Time Before: 0.00461 seconds
Time After: 0.00702 seconds
Time Taken: 0.00241 seconds
Memory Before: 1,189.133 KB
Memory After: 1,190.055 KB
Time Before: 0.00375 seconds
Time After: 0.01094 seconds
Time Taken: 0.00719 seconds
Memory Before: 1,185.750 KB
Memory After: 2,266.781 KB
Time Before: 0.01297 seconds
Time After: 0.01337 seconds
Memory Before: 2,759.484 KB
Memory After: 2,760.102 KB
Time Before: 0.01633 seconds
Time After: 0.01757 seconds
Memory Before: 2,771.656 KB
Memory After: 2,771.516 KB
Time Before: 0.01241 seconds
Time After: 0.01774 seconds
Time Taken: 0.00533 seconds
Memory Before: 2,751.625 KB
Memory After: 2,884.547 KB
Time Before: 0.02297 seconds
Time After: 0.02309 seconds
Memory Before: 3,437.688 KB
Memory After: 3,438.203 KB
Time Before: 0.02498 seconds
Time After: 0.02621 seconds
Memory Before: 3,525.500 KB
Memory After: 3,526.094 KB
Time Before: 0.02946 seconds
Time After: 0.02958 seconds
Memory Before: 4,163.391 KB
Memory After: 4,163.820 KB
Time Before: 0.03161 seconds
Time After: 0.03301 seconds
Memory Before: 4,444.953 KB
Memory After: 4,446.641 KB
UPDATE session SET lastactivity = 1788948970, location = '/forums/private.php?do=newpm&explain=1&u=133464' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04623 seconds
Time After: 0.04663 seconds
Memory Before: 4,918.805 KB
Memory After: 4,919.031 KB
