Time Before: 0.00859 seconds
Time After: 0.01023 seconds
Time Taken: 0.00164 seconds
Time Before: 0.01032 seconds
Time After: 0.01099 seconds
Time Taken: 0.00067 seconds
Time Before: 0.01123 seconds
Time After: 0.01136 seconds
Time Before: 0.01215 seconds
Time After: 0.01513 seconds
Time Taken: 0.00298 seconds
Time Before: 0.01141 seconds
Time After: 0.01854 seconds
Time Taken: 0.00713 seconds
Time Before: 0.02147 seconds
Time After: 0.02168 seconds
Time Before: 0.02322 seconds
Time After: 0.02482 seconds
Time Taken: 0.00159 seconds
Time Before: 0.02083 seconds
Time After: 0.02499 seconds
Time Taken: 0.00416 seconds
Time Before: 0.03478 seconds
Time After: 0.03507 seconds
Time Before: 0.03950 seconds
Time After: 0.04073 seconds
Time Before: 0.04566 seconds
Time After: 0.04579 seconds
Time Before: 0.04839 seconds
Time After: 0.04996 seconds
Time Taken: 0.00157 seconds
UPDATE session SET lastactivity = 1776878712, location = '/forums/private.php?do=newpm&explain=1&u=133467' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.06575 seconds
Time After: 0.06610 seconds
