Time Before: 0.00187 seconds
Time After: 0.00236 seconds
Time Before: 0.00243 seconds
Time After: 0.00280 seconds
Time Before: 0.00304 seconds
Time After: 0.00315 seconds
Time Before: 0.00391 seconds
Time After: 0.00641 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00320 seconds
Time After: 0.00977 seconds
Time Taken: 0.00657 seconds
Time Before: 0.01149 seconds
Time After: 0.01170 seconds
Time Before: 0.01321 seconds
Time After: 0.01448 seconds
Time Before: 0.01092 seconds
Time After: 0.01475 seconds
Time Taken: 0.00383 seconds
Time Before: 0.02218 seconds
Time After: 0.02233 seconds
Time Before: 0.02472 seconds
Time After: 0.02594 seconds
End call of global.php: 0.027647972106934
Time Before: 0.02894 seconds
Time After: 0.02907 seconds
Time Before: 0.03115 seconds
Time After: 0.03260 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=133604', badlocation = 1
Time Before: 0.04495 seconds
Time After: 0.04519 seconds
Page generated in 0.044058084487915 seconds with 9 queries, spending 0.0076596736907959 doing MySQL queries and 0.036398410797119 doing PHP things.
