Time Before: 0.00137 seconds
Time After: 0.00190 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00197 seconds
Time After: 0.00243 seconds
Time Before: 0.00263 seconds
Time After: 0.00276 seconds
Time Before: 0.00346 seconds
Time After: 0.00608 seconds
Time Taken: 0.00261 seconds
Time Before: 0.00282 seconds
Time After: 0.00951 seconds
Time Taken: 0.00669 seconds
Time Before: 0.01144 seconds
Time After: 0.01182 seconds
Time Before: 0.01412 seconds
Time After: 0.01529 seconds
Time Taken: 0.00117 seconds
Time Before: 0.01091 seconds
Time After: 0.01545 seconds
Time Taken: 0.00455 seconds
Time Before: 0.02041 seconds
Time After: 0.02057 seconds
Time Before: 0.02253 seconds
Time After: 0.02379 seconds
Time Before: 0.02664 seconds
Time After: 0.02677 seconds
Time Before: 0.02878 seconds
Time After: 0.03018 seconds
Time Taken: 0.00140 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133606' WHERE sessionhash = '6d76899e3772524375a2c635be997117'
Time Before: 0.04301 seconds
Time After: 0.04329 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
