Time Before: 0.00722 seconds
Time After: 0.01121 seconds
Time Taken: 0.00399 seconds
Time Before: 0.01133 seconds
Time After: 0.01280 seconds
Time Before: 0.01302 seconds
Time After: 0.01314 seconds
Time Before: 0.01405 seconds
Time After: 0.01709 seconds
Time Taken: 0.00305 seconds
Time Before: 0.01322 seconds
Time After: 0.02166 seconds
Time Taken: 0.00844 seconds
Time Before: 0.02673 seconds
Time After: 0.02716 seconds
Time Before: 0.02989 seconds
Time After: 0.03108 seconds
Memory Before: 2,148.938 KB
Memory After: 2,148.797 KB
Time Before: 0.02595 seconds
Time After: 0.03134 seconds
Time Taken: 0.00539 seconds
Memory After: 2,261.820 KB
Time Before: 0.04332 seconds
Time After: 0.04346 seconds
Memory Before: 2,815.367 KB
Memory After: 2,815.883 KB
Time Before: 0.05036 seconds
Time After: 0.05161 seconds
Memory Before: 2,903.563 KB
Memory After: 2,904.156 KB
Time Before: 0.05930 seconds
Time After: 0.05952 seconds
Memory Before: 3,540.328 KB
Memory After: 3,540.758 KB
Time Before: 0.06253 seconds
Time After: 0.06399 seconds
Memory Before: 3,821.859 KB
Memory After: 3,823.547 KB
UPDATE session SET lastactivity = 1788899784, location = '/forums/private.php?do=newpm&explain=1&u=133607', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.08150 seconds
Time After: 0.08225 seconds
Time Taken: 0.00075 seconds
Memory Before: 4,287.836 KB
Memory After: 4,288.047 KB
