Time Before: 0.00133 seconds
Time After: 0.00174 seconds
Time Before: 0.00181 seconds
Time After: 0.00241 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00267 seconds
Time After: 0.00278 seconds
Time Before: 0.00342 seconds
Time After: 0.00596 seconds
Time Taken: 0.00255 seconds
Time Before: 0.00283 seconds
Time After: 0.00930 seconds
Time Taken: 0.00647 seconds
Time Before: 0.01127 seconds
Time After: 0.01168 seconds
Time Before: 0.01418 seconds
Time After: 0.01534 seconds
Time Taken: 0.00116 seconds
Time Before: 0.01063 seconds
Time After: 0.01551 seconds
Time Taken: 0.00488 seconds
Time Before: 0.02032 seconds
Time After: 0.02043 seconds
Time Before: 0.02227 seconds
Time After: 0.02349 seconds
Time Before: 0.02626 seconds
Time After: 0.02639 seconds
Time Before: 0.02836 seconds
Time After: 0.02976 seconds
Time Taken: 0.00140 seconds
UPDATE session SET lastactivity = 1789119977, location = '/forums/private.php?do=newpm&explain=1&u=133621', badlocation = 1 WHERE sessionhash = 'fead92432b1d1f7bb19e50f71f2f4484'
Time Before: 0.04211 seconds
Time After: 0.04249 seconds
