Time Before: 0.01100 seconds
Time After: 0.01660 seconds
Time Taken: 0.00560 seconds
Time Before: 0.01671 seconds
Time After: 0.01712 seconds
Time Before: 0.01736 seconds
Time After: 0.01748 seconds
Time Before: 0.01827 seconds
Time After: 0.02056 seconds
Time Taken: 0.00229 seconds
Time Before: 0.01755 seconds
Time After: 0.02561 seconds
Time Taken: 0.00806 seconds
Time Before: 0.03265 seconds
Time After: 0.03311 seconds
Time Before: 0.03473 seconds
Time After: 0.03609 seconds
Time Taken: 0.00136 seconds
Time Before: 0.03184 seconds
Time After: 0.03630 seconds
Time Taken: 0.00446 seconds
Time Before: 0.05216 seconds
Time After: 0.05229 seconds
Time Before: 0.06371 seconds
Time After: 0.06494 seconds
End call of global.php: 0.066873073577881
Time Before: 0.07155 seconds
Time After: 0.07168 seconds
Time Before: 0.07405 seconds
Time After: 0.07558 seconds
Time Taken: 0.00154 seconds
SET lastactivity = 1785298249, location = '/forums/private.php?do=newpm&explain=1&u=133635', badlocation = 1
Time Before: 0.09522 seconds
Time After: 0.09560 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.093744993209839 seconds with 9 queries, spending 0.0080537796020508 doing MySQL queries and 0.085691213607788 doing PHP things.
