Time Before: 0.00153 seconds
Time After: 0.00209 seconds
Time Taken: 0.00057 seconds
Time Before: 0.00220 seconds
Time After: 0.00281 seconds
Time Taken: 0.00061 seconds
Time Before: 0.00305 seconds
Time After: 0.00320 seconds
Time Before: 0.00400 seconds
Time After: 0.00693 seconds
Time Taken: 0.00292 seconds
Time Before: 0.00325 seconds
Time After: 0.01035 seconds
Time Taken: 0.00711 seconds
Time Before: 0.01219 seconds
Time After: 0.01259 seconds
Time Before: 0.01575 seconds
Time After: 0.01695 seconds
Time Before: 0.01154 seconds
Time After: 0.01711 seconds
Time Taken: 0.00558 seconds
Time Before: 0.02275 seconds
Time After: 0.02288 seconds
Time Before: 0.02464 seconds
Time After: 0.02586 seconds
Time Before: 0.02892 seconds
Time After: 0.02905 seconds
Time Before: 0.03108 seconds
Time After: 0.03259 seconds
Time Taken: 0.00151 seconds
UPDATE session SET lastactivity = 1776879956, location = '/forums/private.php?do=newpm&explain=1&u=13364', badlocation = 1 WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.04489 seconds
Time After: 0.04524 seconds
Memory Before: 4,911.453 KB
Memory After: 4,911.664 KB
