Time Before: 0.00142 seconds
Time After: 0.00196 seconds
Time Taken: 0.00053 seconds
Time Before: 0.00203 seconds
Time After: 0.00274 seconds
Time Taken: 0.00072 seconds
Time Before: 0.00303 seconds
Time After: 0.00320 seconds
Time Before: 0.00387 seconds
Time After: 0.00694 seconds
Time Taken: 0.00307 seconds
Time Before: 0.00325 seconds
Time After: 0.01032 seconds
Time Taken: 0.00707 seconds
Time Before: 0.01246 seconds
Time After: 0.01272 seconds
Time Before: 0.01516 seconds
Time After: 0.01645 seconds
Time Before: 0.01178 seconds
Time After: 0.01663 seconds
Time Taken: 0.00485 seconds
Time Before: 0.02213 seconds
Time After: 0.02235 seconds
Time Before: 0.02469 seconds
Time After: 0.02671 seconds
Time Taken: 0.00202 seconds
End call of global.php: 0.028420925140381
Time Before: 0.02998 seconds
Time After: 0.03018 seconds
Time Before: 0.03225 seconds
Time After: 0.03365 seconds
Time Taken: 0.00140 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=133766'
Time Before: 0.04623 seconds
Time After: 0.04661 seconds
Page generated in 0.045346975326538 seconds with 9 queries, spending 0.0097341537475586 doing MySQL queries and 0.035612821578979 doing PHP things.
