Time Before: 0.01850 seconds
Time After: 0.02433 seconds
Time Taken: 0.00583 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02443 seconds
Time After: 0.02502 seconds
Time Taken: 0.00058 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02532 seconds
Time After: 0.02551 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02636 seconds
Time After: 0.02869 seconds
Time Taken: 0.00233 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02558 seconds
Time After: 0.03376 seconds
Time Taken: 0.00818 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04175 seconds
Time After: 0.04232 seconds
Time Taken: 0.00057 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04595 seconds
Time After: 0.04732 seconds
Time Taken: 0.00136 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04093 seconds
Time After: 0.04761 seconds
Time Taken: 0.00668 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.08102 seconds
Time After: 0.08116 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.12277 seconds
Time After: 0.12441 seconds
Time Taken: 0.00164 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
End call of global.php: 0.12756299972534
Time Before: 0.14675 seconds
Time After: 0.14730 seconds
Time Taken: 0.00056 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.15196 seconds
Time After: 0.15343 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
SET lastactivity = 1772641879, location = '/forums/private.php?do=newpm&explain=1&u=133792', badlocation = 1
WHERE sessionhash = '600503b925d08d481e162d46884ab830'
Time Before: 0.17679 seconds
Time After: 0.17748 seconds
Time Taken: 0.00069 seconds
Memory Before: 5,998.219 KB
Memory After: 5,998.430 KB
Page generated in 0.17578911781311 seconds with 9 queries, spending 0.0095210075378418 doing MySQL queries and 0.16626811027527 doing PHP things.
