Time Before: 0.00468 seconds
Time After: 0.00688 seconds
Time Taken: 0.00220 seconds
Time Before: 0.00695 seconds
Time After: 0.00737 seconds
Time Before: 0.00764 seconds
Time After: 0.00777 seconds
Time Before: 0.00843 seconds
Time After: 0.01062 seconds
Time Taken: 0.00219 seconds
Time Before: 0.00782 seconds
Time After: 0.01401 seconds
Time Taken: 0.00619 seconds
Time Before: 0.01722 seconds
Time After: 0.01755 seconds
Time Before: 0.02009 seconds
Time After: 0.02128 seconds
Time Before: 0.01664 seconds
Time After: 0.02148 seconds
Time Taken: 0.00483 seconds
Time Before: 0.03390 seconds
Time After: 0.03407 seconds
Time Before: 0.03971 seconds
Time After: 0.04112 seconds
End call of global.php: 0.043727874755859
Time Before: 0.04787 seconds
Time After: 0.04804 seconds
Time Before: 0.05089 seconds
Time After: 0.05245 seconds
Time Taken: 0.00156 seconds
SET lastactivity = 1783040288, location = '/forums/private.php?do=newpm&explain=1&u=133826', badlocation = 1
Time Before: 0.07001 seconds
Time After: 0.07029 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.068831920623779 seconds with 9 queries, spending 0.0078597068786621 doing MySQL queries and 0.060972213745117 doing PHP things.
