Time Before: 0.02390 seconds
Time After: 0.03546 seconds
Time Taken: 0.01156 seconds
Time Before: 0.03555 seconds
Time After: 0.03594 seconds
Time Before: 0.03616 seconds
Time After: 0.03631 seconds
Time Before: 0.03719 seconds
Time After: 0.03984 seconds
Time Taken: 0.00265 seconds
Time Before: 0.03639 seconds
Time After: 0.04393 seconds
Time Taken: 0.00754 seconds
Time Before: 0.05779 seconds
Time After: 0.05819 seconds
Time Before: 0.06134 seconds
Time After: 0.06264 seconds
Time Before: 0.05704 seconds
Time After: 0.06288 seconds
Time Taken: 0.00584 seconds
Time Before: 0.12415 seconds
Time After: 0.12429 seconds
Time Before: 0.15109 seconds
Time After: 0.15235 seconds
End call of global.php: 0.15424108505249
Time Before: 0.16743 seconds
Time After: 0.16757 seconds
Time Before: 0.17050 seconds
Time After: 0.17192 seconds
SET lastactivity = 1785336131, location = '/forums/private.php?do=newpm&explain=1&u=133863'
Time Before: 0.19371 seconds
Time After: 0.19404 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.19258308410645 seconds with 9 queries, spending 0.0081837177276611 doing MySQL queries and 0.18439936637878 doing PHP things.
