Time Before: 0.01800 seconds
Time After: 0.02521 seconds
Time Taken: 0.00721 seconds
Time Before: 0.02530 seconds
Time After: 0.02572 seconds
Time Before: 0.02598 seconds
Time After: 0.02612 seconds
Time Before: 0.02690 seconds
Time After: 0.02928 seconds
Time Taken: 0.00238 seconds
Time Before: 0.02618 seconds
Time After: 0.03347 seconds
Time Taken: 0.00729 seconds
Time Before: 0.03762 seconds
Time After: 0.03804 seconds
Time Before: 0.04030 seconds
Time After: 0.04284 seconds
Time Taken: 0.00253 seconds
Time Before: 0.03701 seconds
Time After: 0.04306 seconds
Time Taken: 0.00606 seconds
Time Before: 0.07643 seconds
Time After: 0.07657 seconds
Time Before: 0.08974 seconds
Time After: 0.09099 seconds
End call of global.php: 0.092978000640869
Time Before: 0.09991 seconds
Time After: 0.10007 seconds
Time Before: 0.10247 seconds
Time After: 0.10423 seconds
Time Taken: 0.00176 seconds
SET lastactivity = 1785289905, location = '/forums/private.php?do=newpm&explain=1&u=133867'
Time Before: 0.12065 seconds
Time After: 0.12101 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.11955904960632 seconds with 9 queries, spending 0.0095510482788086 doing MySQL queries and 0.11000800132751 doing PHP things.
