Time Before: 0.00162 seconds
Time After: 0.00216 seconds
Time Taken: 0.00054 seconds
Time Before: 0.00223 seconds
Time After: 0.00268 seconds
Time Before: 0.00297 seconds
Time After: 0.00326 seconds
Time Before: 0.00408 seconds
Time After: 0.00688 seconds
Time Taken: 0.00279 seconds
Time Before: 0.00334 seconds
Time After: 0.01199 seconds
Time Taken: 0.00865 seconds
Time Before: 0.01442 seconds
Time After: 0.01482 seconds
Time Before: 0.01748 seconds
Time After: 0.01872 seconds
Time Before: 0.01366 seconds
Time After: 0.01890 seconds
Time Taken: 0.00524 seconds
Time Before: 0.02558 seconds
Time After: 0.02580 seconds
Time Before: 0.02815 seconds
Time After: 0.02942 seconds
End call of global.php: 0.031188011169434
Time Before: 0.03273 seconds
Time After: 0.03289 seconds
Time Before: 0.03563 seconds
Time After: 0.03707 seconds
SET lastactivity = 1783017849, location = '/forums/private.php?do=newpm&explain=1&u=133876', badlocation = 1
Time Before: 0.05336 seconds
Time After: 0.05367 seconds
Page generated in 0.052404880523682 seconds with 9 queries, spending 0.0085561275482178 doing MySQL queries and 0.043848752975464 doing PHP things.
