Time Before: 0.00235 seconds
Time After: 0.00314 seconds
Time Taken: 0.00079 seconds
Time Before: 0.00321 seconds
Time After: 0.00384 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00407 seconds
Time After: 0.00420 seconds
Time Before: 0.00500 seconds
Time After: 0.00786 seconds
Time Taken: 0.00285 seconds
Time Before: 0.00425 seconds
Time After: 0.01240 seconds
Time Taken: 0.00815 seconds
Time Before: 0.01419 seconds
Time After: 0.01482 seconds
Time Before: 0.01714 seconds
Time After: 0.01833 seconds
Memory Before: 2,148.820 KB
Memory After: 2,148.680 KB
Time Before: 0.01355 seconds
Time After: 0.01850 seconds
Time Taken: 0.00494 seconds
Memory After: 2,261.703 KB
Time Before: 0.02339 seconds
Time After: 0.02363 seconds
Memory Before: 2,815.281 KB
Memory After: 2,815.797 KB
Time Before: 0.02549 seconds
Time After: 0.02725 seconds
Time Taken: 0.00175 seconds
Memory Before: 2,903.477 KB
Memory After: 2,904.070 KB
Time Before: 0.03058 seconds
Time After: 0.03074 seconds
Memory Before: 3,540.234 KB
Memory After: 3,540.664 KB
Time Before: 0.03276 seconds
Time After: 0.03424 seconds
Memory Before: 3,821.766 KB
Memory After: 3,823.453 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=133918', badlocation = 1 WHERE sessionhash = 'f13dd3a27df226bbe6e1fd6696c36073'
Time Before: 0.04635 seconds
Time After: 0.04670 seconds
Memory Before: 4,287.469 KB
Memory After: 4,287.695 KB
