Time Before: 0.00224 seconds
Time After: 0.00344 seconds
Time Before: 0.00350 seconds
Time After: 0.00429 seconds
Time Taken: 0.00078 seconds
Time Before: 0.00457 seconds
Time After: 0.00473 seconds
Time Before: 0.00548 seconds
Time After: 0.00787 seconds
Time Taken: 0.00239 seconds
Time Before: 0.00478 seconds
Time After: 0.01362 seconds
Time Taken: 0.00884 seconds
Time Before: 0.01630 seconds
Time After: 0.01670 seconds
Time Before: 0.01831 seconds
Time After: 0.01958 seconds
Time Before: 0.01558 seconds
Time After: 0.01987 seconds
Time Taken: 0.00430 seconds
Time Before: 0.02736 seconds
Time After: 0.02755 seconds
Time Before: 0.02980 seconds
Time After: 0.03108 seconds
End call of global.php: 0.033751010894775
Time Before: 0.03512 seconds
Time After: 0.03528 seconds
Time Before: 0.03731 seconds
Time After: 0.03881 seconds
SET lastactivity = 1789147402, location = '/forums/private.php?do=newpm&explain=1&u=134010'
Time Before: 0.05329 seconds
Time After: 0.05361 seconds
Page generated in 0.052326202392578 seconds with 9 queries, spending 0.0084283351898193 doing MySQL queries and 0.043897867202759 doing PHP things.
