Time Before: 0.01235 seconds
Time After: 0.01730 seconds
Time Taken: 0.00495 seconds
Time Before: 0.01741 seconds
Time After: 0.01792 seconds
Time Before: 0.01821 seconds
Time After: 0.01835 seconds
Time Before: 0.01917 seconds
Time After: 0.02187 seconds
Time Taken: 0.00270 seconds
Time Before: 0.01841 seconds
Time After: 0.02716 seconds
Time Taken: 0.00875 seconds
Time Before: 0.03236 seconds
Time After: 0.03260 seconds
Time Before: 0.03510 seconds
Time After: 0.03642 seconds
Time Taken: 0.00131 seconds
Time Before: 0.03162 seconds
Time After: 0.03662 seconds
Time Taken: 0.00500 seconds
Time Before: 0.05659 seconds
Time After: 0.05675 seconds
Time Before: 0.06629 seconds
Time After: 0.06756 seconds
End call of global.php: 0.069784879684448
Time Before: 0.07339 seconds
Time After: 0.07357 seconds
Time Before: 0.07615 seconds
Time After: 0.07762 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=134027', badlocation = 1
Time Before: 0.09258 seconds
Time After: 0.09284 seconds
Memory Before: 4,288.203 KB
Memory After: 4,288.430 KB
Page generated in 0.091660976409912 seconds with 9 queries, spending 0.0082435607910156 doing MySQL queries and 0.083417415618896 doing PHP things.
