Time Before: 0.01527 seconds
Time After: 0.02434 seconds
Time Taken: 0.00908 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02447 seconds
Time After: 0.02485 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02508 seconds
Time After: 0.02525 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02596 seconds
Time After: 0.02846 seconds
Time Taken: 0.00250 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02532 seconds
Time After: 0.03326 seconds
Time Taken: 0.00794 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04336 seconds
Time After: 0.04372 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04653 seconds
Time After: 0.04808 seconds
Time Taken: 0.00155 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04267 seconds
Time After: 0.04830 seconds
Time Taken: 0.00564 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.09208 seconds
Time After: 0.09224 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.14807 seconds
Time After: 0.14932 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.17473 seconds
Time After: 0.17491 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.18011 seconds
Time After: 0.18158 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773179226, location = '/forums/private.php?do=newpm&explain=1&u=134063', badlocation = 1 WHERE sessionhash = 'fb8546df1d172120a5a514bbe0406f9a'
Time Before: 0.21288 seconds
Time After: 0.21319 seconds
Memory Before: 5,999.000 KB
Memory After: 5,999.211 KB
