Time Before: 0.00137 seconds
Time After: 0.00264 seconds
Time Before: 0.00272 seconds
Time After: 0.00487 seconds
Time Taken: 0.00215 seconds
Time Before: 0.00520 seconds
Time After: 0.00534 seconds
Time Before: 0.00626 seconds
Time After: 0.00885 seconds
Time Taken: 0.00260 seconds
Time Before: 0.00541 seconds
Time After: 0.01233 seconds
Time Taken: 0.00692 seconds
Time Before: 0.01400 seconds
Time After: 0.01450 seconds
Time Before: 0.01711 seconds
Time After: 0.01838 seconds
Time Before: 0.01344 seconds
Time After: 0.01859 seconds
Time Taken: 0.00516 seconds
Time Before: 0.02567 seconds
Time After: 0.02585 seconds
Time Before: 0.02785 seconds
Time After: 0.02925 seconds
Time Before: 0.03330 seconds
Time After: 0.03349 seconds
Time Before: 0.03664 seconds
Time After: 0.03807 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=134067' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.05216 seconds
Time After: 0.05240 seconds
