Time Before: 0.00143 seconds
Time After: 0.00203 seconds
Time Taken: 0.00059 seconds
Time Before: 0.00209 seconds
Time After: 0.00264 seconds
Time Taken: 0.00055 seconds
Time Before: 0.00289 seconds
Time After: 0.00300 seconds
Time Before: 0.00365 seconds
Time After: 0.00615 seconds
Time Taken: 0.00251 seconds
Time Before: 0.00305 seconds
Time After: 0.01096 seconds
Time Taken: 0.00791 seconds
Time Before: 0.01328 seconds
Time After: 0.01366 seconds
Time Before: 0.01653 seconds
Time After: 0.01778 seconds
Time Before: 0.01251 seconds
Time After: 0.01794 seconds
Time Taken: 0.00543 seconds
Time Before: 0.02283 seconds
Time After: 0.02296 seconds
Time Before: 0.02468 seconds
Time After: 0.02632 seconds
Time Taken: 0.00164 seconds
Time Before: 0.02915 seconds
Time After: 0.02928 seconds
Time Before: 0.03130 seconds
Time After: 0.03289 seconds
Time Taken: 0.00159 seconds
UPDATE session SET lastactivity = 1773280041, location = '/forums/private.php?do=newpm&explain=1&u=134075', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.04729 seconds
Time After: 0.04760 seconds
