Time Before: 0.00147 seconds
Time After: 0.00199 seconds
Time Before: 0.00205 seconds
Time After: 0.00236 seconds
Time Before: 0.00254 seconds
Time After: 0.00272 seconds
Time Before: 0.00340 seconds
Time After: 0.00556 seconds
Time Taken: 0.00217 seconds
Time Before: 0.00276 seconds
Time After: 0.01022 seconds
Time Taken: 0.00745 seconds
Time Before: 0.01208 seconds
Time After: 0.01244 seconds
Time Before: 0.01499 seconds
Time After: 0.01617 seconds
Time Taken: 0.00118 seconds
Time Before: 0.01147 seconds
Time After: 0.01634 seconds
Time Taken: 0.00487 seconds
Time Before: 0.02243 seconds
Time After: 0.02258 seconds
Time Before: 0.02486 seconds
Time After: 0.02611 seconds
Time Before: 0.02908 seconds
Time After: 0.02925 seconds
Time Before: 0.03131 seconds
Time After: 0.03278 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=134121' WHERE sessionhash = 'f0a2de90bc45baf36aaf71071f1bfe42'
Time Before: 0.04582 seconds
Time After: 0.04616 seconds
