Time Before: 0.01347 seconds
Time After: 0.02190 seconds
Time Taken: 0.00843 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.02198 seconds
Time After: 0.02242 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.02281 seconds
Time After: 0.02293 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.02382 seconds
Time After: 0.02639 seconds
Time Taken: 0.00257 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.02301 seconds
Time After: 0.03098 seconds
Time Taken: 0.00797 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.04458 seconds
Time After: 0.04500 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.04776 seconds
Time After: 0.04895 seconds
Memory Before: 2,908.383 KB
Memory After: 2,908.242 KB
Time Before: 0.04390 seconds
Time After: 0.04913 seconds
Time Taken: 0.00523 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.297 KB
Memory Used: 132.633 KB
Time Before: 0.07624 seconds
Time After: 0.07644 seconds
Memory Before: 3,655.813 KB
Memory After: 3,656.328 KB
Time Before: 0.11470 seconds
Time After: 0.11608 seconds
Time Taken: 0.00138 seconds
Memory Before: 4,133.500 KB
Memory After: 4,134.094 KB
Time Before: 0.13903 seconds
Time After: 0.13920 seconds
Memory Before: 5,197.727 KB
Memory After: 5,326.070 KB
Time Before: 0.14512 seconds
Time After: 0.14660 seconds
Memory Before: 5,481.406 KB
Memory After: 5,611.008 KB
UPDATE session SET lastactivity = 1773324128, location = '/forums/private.php?do=newpm&explain=1&u=134190' WHERE sessionhash = 'eaa8a3ac54cff5a66f956999e9bca4a9'
Time Before: 0.16954 seconds
Time After: 0.16984 seconds
Memory Before: 5,997.945 KB
Memory After: 5,998.164 KB
