Time Before: 0.02608 seconds
Time After: 0.03961 seconds
Time Taken: 0.01353 seconds
Time Before: 0.03970 seconds
Time After: 0.04013 seconds
Time Before: 0.04037 seconds
Time After: 0.04053 seconds
Time Before: 0.04134 seconds
Time After: 0.04358 seconds
Time Taken: 0.00224 seconds
Time Before: 0.04059 seconds
Time After: 0.04768 seconds
Time Taken: 0.00709 seconds
Time Before: 0.06101 seconds
Time After: 0.06145 seconds
Time Before: 0.06451 seconds
Time After: 0.06704 seconds
Time Taken: 0.00252 seconds
Time Before: 0.06022 seconds
Time After: 0.06728 seconds
Time Taken: 0.00706 seconds
Time Before: 0.10945 seconds
Time After: 0.10959 seconds
Time Before: 0.14123 seconds
Time After: 0.14245 seconds
Time Before: 0.15129 seconds
Time After: 0.15144 seconds
Time Before: 0.15411 seconds
Time After: 0.15554 seconds
UPDATE session SET lastactivity = 1785294201, location = '/forums/private.php?do=newpm&explain=1&u=134235' WHERE sessionhash = '1bdac016e56aac80b5f324b5c0ae82e4'
Time Before: 0.17445 seconds
Time After: 0.17478 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
