Time Before: 0.00739 seconds
Time After: 0.01112 seconds
Time Taken: 0.00373 seconds
Time Before: 0.01123 seconds
Time After: 0.01162 seconds
Time Before: 0.01184 seconds
Time After: 0.01195 seconds
Time Before: 0.01271 seconds
Time After: 0.01512 seconds
Time Taken: 0.00240 seconds
Time Before: 0.01200 seconds
Time After: 0.01939 seconds
Time Taken: 0.00739 seconds
Time Before: 0.02412 seconds
Time After: 0.02451 seconds
Time Before: 0.02701 seconds
Time After: 0.02832 seconds
Time Taken: 0.00131 seconds
Time Before: 0.02338 seconds
Time After: 0.02859 seconds
Time Taken: 0.00521 seconds
Time Before: 0.04415 seconds
Time After: 0.04431 seconds
Time Before: 0.05198 seconds
Time After: 0.05325 seconds
End call of global.php: 0.055136919021606
Time Before: 0.05862 seconds
Time After: 0.05878 seconds
Time Before: 0.06108 seconds
Time After: 0.06255 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=134248'
Time Before: 0.08012 seconds
Time After: 0.08038 seconds
Memory Before: 4,288.695 KB
Memory After: 4,288.938 KB
Page generated in 0.078984022140503 seconds with 9 queries, spending 0.0079281330108643 doing MySQL queries and 0.071055889129639 doing PHP things.
