Time Before: 0.01402 seconds
Time After: 0.01665 seconds
Time Taken: 0.00263 seconds
Time Before: 0.01676 seconds
Time After: 0.01723 seconds
Time Before: 0.01747 seconds
Time After: 0.01762 seconds
Time Before: 0.01853 seconds
Time After: 0.02095 seconds
Time Taken: 0.00242 seconds
Time Before: 0.01769 seconds
Time After: 0.02459 seconds
Time Taken: 0.00690 seconds
Time Before: 0.02952 seconds
Time After: 0.02993 seconds
Time Before: 0.03247 seconds
Time After: 0.03368 seconds
Time Before: 0.02893 seconds
Time After: 0.03387 seconds
Time Taken: 0.00494 seconds
Time Before: 0.05644 seconds
Time After: 0.05675 seconds
Time Before: 0.06730 seconds
Time After: 0.06856 seconds
End call of global.php: 0.070777893066406
Time Before: 0.07588 seconds
Time After: 0.07606 seconds
Time Before: 0.07849 seconds
Time After: 0.07992 seconds
SET lastactivity = 1776897756, location = '/forums/private.php?do=newpm&explain=1&u=134290'
Time Before: 0.09588 seconds
Time After: 0.09616 seconds
Memory Before: 4,288.266 KB
Memory After: 4,288.492 KB
Page generated in 0.094945907592773 seconds with 9 queries, spending 0.0081255435943604 doing MySQL queries and 0.086820363998413 doing PHP things.
