Time Before: 0.00370 seconds
Time After: 0.00529 seconds
Time Taken: 0.00159 seconds
Time Before: 0.00538 seconds
Time After: 0.00598 seconds
Time Taken: 0.00060 seconds
Time Before: 0.00621 seconds
Time After: 0.00636 seconds
Time Before: 0.00714 seconds
Time After: 0.00944 seconds
Time Taken: 0.00230 seconds
Time Before: 0.00644 seconds
Time After: 0.01417 seconds
Time Taken: 0.00774 seconds
Time Before: 0.01774 seconds
Time After: 0.01812 seconds
Time Before: 0.02062 seconds
Time After: 0.02188 seconds
Time Before: 0.01694 seconds
Time After: 0.02216 seconds
Time Taken: 0.00522 seconds
Time Before: 0.03530 seconds
Time After: 0.03544 seconds
Time Before: 0.04047 seconds
Time After: 0.04171 seconds
Time Before: 0.04572 seconds
Time After: 0.04598 seconds
Time Before: 0.04820 seconds
Time After: 0.04968 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=134331' WHERE sessionhash = '5dcfbb55b5add1e7cfb509ae0e835a95'
Time Before: 0.06229 seconds
Time After: 0.06266 seconds
