Time Before: 0.00776 seconds
Time After: 0.01284 seconds
Time Taken: 0.00508 seconds
Time Before: 0.01294 seconds
Time After: 0.01341 seconds
Time Before: 0.01397 seconds
Time After: 0.01413 seconds
Time Before: 0.01486 seconds
Time After: 0.01687 seconds
Time Taken: 0.00200 seconds
Time Before: 0.01420 seconds
Time After: 0.02095 seconds
Time Taken: 0.00675 seconds
Time Before: 0.03122 seconds
Time After: 0.03168 seconds
Time Before: 0.03422 seconds
Time After: 0.03548 seconds
Time Before: 0.03035 seconds
Time After: 0.03567 seconds
Time Taken: 0.00533 seconds
Time Before: 0.05147 seconds
Time After: 0.05161 seconds
Time Before: 0.06499 seconds
Time After: 0.06627 seconds
Time Before: 0.07408 seconds
Time After: 0.07424 seconds
Time Before: 0.07675 seconds
Time After: 0.07818 seconds
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=134383' WHERE sessionhash = '3c1d29d6e59a1d652dc9473cfb455cd5'
Time Before: 0.09596 seconds
Time After: 0.09620 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
