Time Before: 0.00159 seconds
Time After: 0.00300 seconds
Time Before: 0.00309 seconds
Time After: 0.00430 seconds
Time Before: 0.00455 seconds
Time After: 0.00468 seconds
Time Before: 0.00532 seconds
Time After: 0.00728 seconds
Time Taken: 0.00196 seconds
Time Before: 0.00473 seconds
Time After: 0.01065 seconds
Time Taken: 0.00592 seconds
Time Before: 0.01270 seconds
Time After: 0.01310 seconds
Time Before: 0.01566 seconds
Time After: 0.01686 seconds
Time Before: 0.01209 seconds
Time After: 0.01704 seconds
Time Taken: 0.00495 seconds
Time Before: 0.02305 seconds
Time After: 0.02319 seconds
Time Before: 0.02606 seconds
Time After: 0.02731 seconds
End call of global.php: 0.029026031494141
Time Before: 0.03051 seconds
Time After: 0.03095 seconds
Time Before: 0.03311 seconds
Time After: 0.03468 seconds
Time Taken: 0.00157 seconds
SET lastactivity = 1789094926, location = '/forums/private.php?do=newpm&explain=1&u=134412', badlocation = 1
Time Before: 0.05065 seconds
Time After: 0.05197 seconds
Time Taken: 0.00132 seconds
Page generated in 0.049723148345947 seconds with 9 queries, spending 0.0095996856689453 doing MySQL queries and 0.040123462677002 doing PHP things.
