Time Before: 0.01603 seconds
Time After: 0.02139 seconds
Time Taken: 0.00537 seconds
Time Before: 0.02148 seconds
Time After: 0.02191 seconds
Time Before: 0.02219 seconds
Time After: 0.02232 seconds
Time Before: 0.02313 seconds
Time After: 0.02613 seconds
Time Taken: 0.00300 seconds
Time Before: 0.02239 seconds
Time After: 0.03001 seconds
Time Taken: 0.00762 seconds
Time Before: 0.03718 seconds
Time After: 0.03753 seconds
Time Before: 0.04031 seconds
Time After: 0.04155 seconds
Time Before: 0.03650 seconds
Time After: 0.04173 seconds
Time Taken: 0.00523 seconds
Time Before: 0.06818 seconds
Time After: 0.06830 seconds
Time Before: 0.14796 seconds
Time After: 0.14921 seconds
Time Before: 0.16013 seconds
Time After: 0.16032 seconds
Time Before: 0.16317 seconds
Time After: 0.16461 seconds
UPDATE session SET lastactivity = 1783181806, location = '/forums/private.php?do=newpm&explain=1&u=134415', badlocation = 1 WHERE sessionhash = '7ca6ab718f0d2129a0db1a6bd7e3c55b'
Time Before: 0.18137 seconds
Time After: 0.18163 seconds
Memory Before: 4,912.320 KB
Memory After: 4,912.531 KB
