Time Before: 0.02539 seconds
Time After: 0.03141 seconds
Time Taken: 0.00602 seconds
Time Before: 0.03152 seconds
Time After: 0.03281 seconds
Time Before: 0.03302 seconds
Time After: 0.03315 seconds
Time Before: 0.03393 seconds
Time After: 0.03586 seconds
Time Taken: 0.00193 seconds
Time Before: 0.03323 seconds
Time After: 0.04127 seconds
Time Taken: 0.00804 seconds
Time Before: 0.05337 seconds
Time After: 0.05389 seconds
Time Before: 0.05593 seconds
Time After: 0.05736 seconds
Time Before: 0.05271 seconds
Time After: 0.05757 seconds
Time Taken: 0.00487 seconds
Time Before: 0.09085 seconds
Time After: 0.09098 seconds
Time Before: 0.11055 seconds
Time After: 0.11178 seconds
End call of global.php: 0.11402297019958
Time Before: 0.12295 seconds
Time After: 0.12311 seconds
Time Before: 0.12537 seconds
Time After: 0.12683 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=134422'
Time Before: 0.14799 seconds
Time After: 0.14825 seconds
Memory Before: 4,287.922 KB
Memory After: 4,288.164 KB
Page generated in 0.14689111709595 seconds with 9 queries, spending 0.0085501670837402 doing MySQL queries and 0.13834095001221 doing PHP things.
