Time Before: 0.00187 seconds
Time After: 0.00249 seconds
Time Taken: 0.00063 seconds
Time Before: 0.00256 seconds
Time After: 0.00301 seconds
Time Before: 0.00322 seconds
Time After: 0.00336 seconds
Time Before: 0.00409 seconds
Time After: 0.00680 seconds
Time Taken: 0.00271 seconds
Time Before: 0.00340 seconds
Time After: 0.01149 seconds
Time Taken: 0.00808 seconds
Time Before: 0.01351 seconds
Time After: 0.01395 seconds
Time Before: 0.01636 seconds
Time After: 0.01757 seconds
Time Before: 0.01282 seconds
Time After: 0.01775 seconds
Time Taken: 0.00493 seconds
Time Before: 0.02300 seconds
Time After: 0.02321 seconds
Time Before: 0.02521 seconds
Time After: 0.02650 seconds
End call of global.php: 0.028169870376587
Time Before: 0.02931 seconds
Time After: 0.02947 seconds
Time Before: 0.03154 seconds
Time After: 0.03298 seconds
SET lastactivity = 1789016001, location = '/forums/private.php?do=newpm&explain=1&u=134460', badlocation = 1
Time Before: 0.04559 seconds
Time After: 0.04586 seconds
Page generated in 0.044661998748779 seconds with 9 queries, spending 0.0083138942718506 doing MySQL queries and 0.036348104476929 doing PHP things.
