Time Before: 0.02445 seconds
Time After: 0.03250 seconds
Time Taken: 0.00805 seconds
Time Before: 0.03261 seconds
Time After: 0.03302 seconds
Time Before: 0.03325 seconds
Time After: 0.03342 seconds
Time Before: 0.03442 seconds
Time After: 0.03675 seconds
Time Taken: 0.00233 seconds
Time Before: 0.03350 seconds
Time After: 0.04083 seconds
Time Taken: 0.00733 seconds
Time Before: 0.04669 seconds
Time After: 0.04689 seconds
Time Before: 0.04960 seconds
Time After: 0.05078 seconds
Time Before: 0.04604 seconds
Time After: 0.05100 seconds
Time Taken: 0.00496 seconds
Time Before: 0.09303 seconds
Time After: 0.09318 seconds
Time Before: 0.10746 seconds
Time After: 0.10872 seconds
End call of global.php: 0.11134886741638
Time Before: 0.11898 seconds
Time After: 0.11912 seconds
Time Before: 0.12168 seconds
Time After: 0.12311 seconds
SET lastactivity = 1785289459, location = '/forums/private.php?do=newpm&explain=1&u=134535', badlocation = 1
Time Before: 0.14164 seconds
Time After: 0.14198 seconds
Page generated in 0.14065480232239 seconds with 9 queries, spending 0.0075950622558594 doing MySQL queries and 0.13305974006653 doing PHP things.
