Time Before: 0.00282 seconds
Time After: 0.00351 seconds
Time Taken: 0.00069 seconds
Time Before: 0.00358 seconds
Time After: 0.00403 seconds
Time Before: 0.00422 seconds
Time After: 0.00436 seconds
Time Before: 0.00504 seconds
Time After: 0.00745 seconds
Time Taken: 0.00241 seconds
Time Before: 0.00441 seconds
Time After: 0.01279 seconds
Time Taken: 0.00838 seconds
Time Before: 0.01538 seconds
Time After: 0.01578 seconds
Time Before: 0.01843 seconds
Time After: 0.01962 seconds
Time Before: 0.01460 seconds
Time After: 0.01988 seconds
Time Taken: 0.00528 seconds
Time Before: 0.02776 seconds
Time After: 0.02792 seconds
Time Before: 0.03029 seconds
Time After: 0.03154 seconds
Time Before: 0.03650 seconds
Time After: 0.03667 seconds
Time Before: 0.03989 seconds
Time After: 0.04135 seconds
UPDATE session SET lastactivity = 1773380485, location = '/forums/private.php?do=newpm&explain=1&u=134567' WHERE sessionhash = 'e0f0ca8e3048a6e309b58c7aba652665'
Time Before: 0.05427 seconds
Time After: 0.05461 seconds
