Time Before: 0.02380 seconds
Time After: 0.02839 seconds
Time Taken: 0.00459 seconds
Time Before: 0.02850 seconds
Time After: 0.02889 seconds
Time Before: 0.02912 seconds
Time After: 0.02923 seconds
Time Before: 0.02998 seconds
Time After: 0.03288 seconds
Time Taken: 0.00290 seconds
Time Before: 0.02928 seconds
Time After: 0.03719 seconds
Time Taken: 0.00792 seconds
Time Before: 0.04276 seconds
Time After: 0.04315 seconds
Time Before: 0.04606 seconds
Time After: 0.04728 seconds
Time Before: 0.04186 seconds
Time After: 0.04749 seconds
Time Taken: 0.00563 seconds
Time Before: 0.08587 seconds
Time After: 0.08604 seconds
Time Before: 0.10486 seconds
Time After: 0.10609 seconds
End call of global.php: 0.10816383361816
Time Before: 0.11528 seconds
Time After: 0.11544 seconds
Time Before: 0.11845 seconds
Time After: 0.11985 seconds
Time Taken: 0.00140 seconds
SET lastactivity = 1785364686, location = '/forums/private.php?do=newpm&explain=1&u=134685', badlocation = 1
Time Before: 0.13557 seconds
Time After: 0.13589 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.13455700874329 seconds with 9 queries, spending 0.0082881450653076 doing MySQL queries and 0.12626886367798 doing PHP things.
