Time Before: 0.00406 seconds
Time After: 0.00528 seconds
Time Before: 0.00535 seconds
Time After: 0.00571 seconds
Time Before: 0.00590 seconds
Time After: 0.00602 seconds
Time Before: 0.00677 seconds
Time After: 0.00961 seconds
Time Taken: 0.00283 seconds
Time Before: 0.00607 seconds
Time After: 0.01577 seconds
Time Taken: 0.00969 seconds
Time Before: 0.01892 seconds
Time After: 0.01934 seconds
Time Before: 0.02108 seconds
Time After: 0.02229 seconds
Time Before: 0.01819 seconds
Time After: 0.02253 seconds
Time Taken: 0.00435 seconds
Time Before: 0.03284 seconds
Time After: 0.03301 seconds
Time Before: 0.03803 seconds
Time After: 0.03929 seconds
End call of global.php: 0.042109966278076
Time Before: 0.04474 seconds
Time After: 0.04491 seconds
Time Before: 0.04801 seconds
Time After: 0.04947 seconds
SET lastactivity = 1782872504, location = '/forums/private.php?do=newpm&explain=1&u=134691', badlocation = 1
WHERE sessionhash = '708f3049c6f4aeb346a0a4658c824d43'
Time Before: 0.06576 seconds
Time After: 0.06604 seconds
Memory Before: 4,288.547 KB
Memory After: 4,288.758 KB
Page generated in 0.064471006393433 seconds with 9 queries, spending 0.0082826614379883 doing MySQL queries and 0.056188344955444 doing PHP things.
