Time Before: 0.02417 seconds
Time After: 0.03250 seconds
Time Taken: 0.00833 seconds
Memory Before: 1,246.250 KB
Memory After: 1,273.055 KB
Time Before: 0.03262 seconds
Time After: 0.03317 seconds
Time Taken: 0.00056 seconds
Memory Before: 1,273.016 KB
Memory After: 1,273.992 KB
Time Before: 0.03344 seconds
Time After: 0.03359 seconds
Memory Before: 1,274.633 KB
Memory After: 1,275.156 KB
Time Before: 0.03437 seconds
Time After: 0.03714 seconds
Time Taken: 0.00277 seconds
Memory Before: 1,278.023 KB
Memory After: 1,278.945 KB
Time Before: 0.03365 seconds
Time After: 0.04264 seconds
Time Taken: 0.00899 seconds
Memory Before: 1,274.438 KB
Memory After: 2,355.672 KB
Memory Used: 1,081.234 KB
Time Before: 0.05300 seconds
Time After: 0.05350 seconds
Memory Before: 2,895.938 KB
Memory After: 2,896.555 KB
Time Before: 0.05589 seconds
Time After: 0.05723 seconds
Time Taken: 0.00134 seconds
Memory Before: 2,908.266 KB
Memory After: 2,908.125 KB
Time Before: 0.05221 seconds
Time After: 0.05748 seconds
Time Taken: 0.00527 seconds
Memory Before: 2,888.664 KB
Memory After: 3,021.180 KB
Memory Used: 132.516 KB
Time Before: 0.09361 seconds
Time After: 0.09379 seconds
Memory Before: 3,655.820 KB
Memory After: 3,656.336 KB
Time Before: 0.13715 seconds
Time After: 0.13845 seconds
Memory Before: 4,133.383 KB
Memory After: 4,133.977 KB
Time Before: 0.16744 seconds
Time After: 0.16764 seconds
Memory Before: 5,197.555 KB
Memory After: 5,325.898 KB
Time Before: 0.17222 seconds
Time After: 0.17370 seconds
Memory Before: 5,481.250 KB
Memory After: 5,610.852 KB
UPDATE session SET location = '/forums/private.php?do=newpm&explain=1&u=134762', badlocation = 1 WHERE sessionhash = '4737b6efab9faed20c53299b3b330814'
Time Before: 0.20041 seconds
Time After: 0.20279 seconds
Time Taken: 0.00238 seconds
Memory Before: 5,997.836 KB
Memory After: 5,998.055 KB
