Time Before: 0.00522 seconds
Time After: 0.00730 seconds
Time Taken: 0.00208 seconds
Time Before: 0.00738 seconds
Time After: 0.00773 seconds
Time Before: 0.00797 seconds
Time After: 0.00814 seconds
Time Before: 0.00897 seconds
Time After: 0.01146 seconds
Time Taken: 0.00250 seconds
Time Before: 0.00821 seconds
Time After: 0.01492 seconds
Time Taken: 0.00670 seconds
Time Before: 0.01894 seconds
Time After: 0.01933 seconds
Time Before: 0.02172 seconds
Time After: 0.02291 seconds
Time Before: 0.01841 seconds
Time After: 0.02312 seconds
Time Taken: 0.00471 seconds
Time Before: 0.03234 seconds
Time After: 0.03251 seconds
Time Before: 0.03822 seconds
Time After: 0.04052 seconds
Time Taken: 0.00230 seconds
End call of global.php: 0.043278932571411
Time Before: 0.04681 seconds
Time After: 0.04698 seconds
Time Before: 0.04941 seconds
Time After: 0.05180 seconds
Time Taken: 0.00239 seconds
SET lastactivity = 1776620006, location = '/forums/private.php?do=newpm&explain=1&u=134826', badlocation = 1
Time Before: 0.06998 seconds
Time After: 0.07030 seconds
Page generated in 0.068840980529785 seconds with 9 queries, spending 0.0099465847015381 doing MySQL queries and 0.058894395828247 doing PHP things.
