Time Before: 0.01858 seconds
Time After: 0.02526 seconds
Time Taken: 0.00668 seconds
Time Before: 0.02536 seconds
Time After: 0.02576 seconds
Time Before: 0.02598 seconds
Time After: 0.02612 seconds
Time Before: 0.02701 seconds
Time After: 0.02938 seconds
Time Taken: 0.00237 seconds
Time Before: 0.02619 seconds
Time After: 0.03337 seconds
Time Taken: 0.00718 seconds
Time Before: 0.04074 seconds
Time After: 0.04114 seconds
Time Before: 0.04365 seconds
Time After: 0.04483 seconds
Time Taken: 0.00118 seconds
Time Before: 0.04008 seconds
Time After: 0.04503 seconds
Time Taken: 0.00495 seconds
Time Before: 0.08003 seconds
Time After: 0.08019 seconds
Time Before: 0.10238 seconds
Time After: 0.10363 seconds
End call of global.php: 0.10584092140198
Time Before: 0.11267 seconds
Time After: 0.11285 seconds
Time Before: 0.11530 seconds
Time After: 0.11673 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=134831', badlocation = 1
Time Before: 0.13563 seconds
Time After: 0.13591 seconds
Memory Before: 4,288.977 KB
Memory After: 4,289.203 KB
Page generated in 0.13462495803833 seconds with 9 queries, spending 0.0077877044677734 doing MySQL queries and 0.12683725357056 doing PHP things.
