Time Before: 0.00205 seconds
Time After: 0.00262 seconds
Time Taken: 0.00056 seconds
Time Before: 0.00272 seconds
Time After: 0.00315 seconds
Time Before: 0.00344 seconds
Time After: 0.00361 seconds
Time Before: 0.00449 seconds
Time After: 0.00725 seconds
Time Taken: 0.00276 seconds
Time Before: 0.00369 seconds
Time After: 0.01198 seconds
Time Taken: 0.00829 seconds
Time Before: 0.01401 seconds
Time After: 0.01444 seconds
Time Before: 0.01731 seconds
Time After: 0.01857 seconds
Time Before: 0.01327 seconds
Time After: 0.01883 seconds
Time Taken: 0.00556 seconds
Time Before: 0.02392 seconds
Time After: 0.02404 seconds
Time Before: 0.02581 seconds
Time After: 0.02707 seconds
Time Before: 0.03041 seconds
Time After: 0.03073 seconds
Time Before: 0.03270 seconds
Time After: 0.03415 seconds
UPDATE session SET lastactivity = 1788972351, location = '/forums/private.php?do=newpm&explain=1&u=13484' WHERE sessionhash = '7fe2d67a1fab00498787d8dbbdf69797'
Time Before: 0.04713 seconds
Time After: 0.04762 seconds
Memory Before: 4,911.172 KB
Memory After: 4,911.398 KB
