Time Before: 0.00163 seconds
Time After: 0.00281 seconds
Time Taken: 0.00118 seconds
Time Before: 0.00289 seconds
Time After: 0.00336 seconds
Time Before: 0.00355 seconds
Time After: 0.00366 seconds
Time Before: 0.00437 seconds
Time After: 0.00728 seconds
Time Taken: 0.00290 seconds
Time Before: 0.00371 seconds
Time After: 0.01065 seconds
Time Taken: 0.00695 seconds
Time Before: 0.01256 seconds
Time After: 0.01295 seconds
Time Before: 0.01568 seconds
Time After: 0.01683 seconds
Time Taken: 0.00115 seconds
Time Before: 0.01199 seconds
Time After: 0.01700 seconds
Time Taken: 0.00501 seconds
Time Before: 0.02219 seconds
Time After: 0.02230 seconds
Time Before: 0.02522 seconds
Time After: 0.02694 seconds
Time Taken: 0.00172 seconds
End call of global.php: 0.028599977493286
Time Before: 0.02992 seconds
Time After: 0.03037 seconds
Time Before: 0.03240 seconds
Time After: 0.03451 seconds
Time Taken: 0.00212 seconds
SET location = '/forums/private.php?do=newpm&explain=1&u=134935'
Time Before: 0.04704 seconds
Time After: 0.04742 seconds
Page generated in 0.04612398147583 seconds with 9 queries, spending 0.0097963809967041 doing MySQL queries and 0.036327600479126 doing PHP things.
